ANALOGIN Problems
I just started·to work with the ANALOGIN command, and it works fine for Vdd and Vss(255, 0, respectively), but it doesn't work for any value in between(I have a voltage divider composed of two 10k resistors connected to Vdd and Vss). Could I please have some help?
RoboGeek
"I reject your reality and subsitute my own!"
Adam Savage, Mythbusters
www.parallax.com
www.goldmine-elec.com
www.expresspcb.com
www.startrek.com
RoboGeek
www.parallax.com
www.expresspcb.com
www.startrek.com
What value to you get ? What cap value are you using ?
Details man, we need details...
P.S. Are you setting the input pin to CMOS trigger level ?
Bean.
Don't mistake experience for intelligence. And vis-vera.
RoboGeek
www.parallax.com
www.expresspcb.com
www.startrek.com
Does the voltage measure 2.5V on a meter ?
Try a larger prime value.
Double check your connections.
Bean.
RoboGeek
www.parallax.com
www.expresspcb.com
www.startrek.com
Try using RB.0 & RB.1 like the example.
Bean.
RoboGeek
www.parallax.com
www.expresspcb.com
www.startrek.com
Persistance pays...
Bean.
Just for information,
Where (apart on this forum's trhead) there are informations on the new command ANALOGIN?
I searched in the help window and there's no mention of such a command,
I searched also the What's new section of the SX basic and there's only
This is all i could find about.
Please more informations needed
Regards
Stefano
Post Edited (ellizard) : 10/17/2006 10:51:03 AM GMT
You can also try looking in the help for the Javelin. It has a similar command. I thinks it's called "ADC" on the javelin.
I hope this helps,
Bean.
hope it will be in SX-Basic help window too.......
it helped somehow
Stefano
