Simple Serial question
I am trying to rec'v serial commands from an external device. This device can't be changed.
What I am trying to do is control a LCD projector.
There are only four commands:
On
Off
RGB input
Video input
The On and Off commands are six bytes long and the RGB and Video are 8 bytes long.
All that is being done is the input to the BS2 is reading what button was pressed.
The baud is 38400.
With the Serin command I have setup an array of 8 bytes so when you press the 8 byte button it works great but when a 6 byte button is pressed the last two bytes don't get filled so the command waits. If I put a timeout in the command then some data may be missed completely when the code exits the Serin.
Just to explain this another way!
My input string is:
02 00 00 00 00 02 'On cmd'
02 01 00 00 00 03 'Off cmd'
02 03 00 00 02 01 01 09 'RGB input'
02 03 00 00 02 01 06 0E 'Video input'
These come in at 38400 baud.
A user can press any button at any time.
I need to see the string and determine what button was pressed then do my task according to the button pressed.
The problem I can't seem to get around is the fact that one string is 6 bytes and the other is eight.
The code I wrote so far is short:
bytearray var byte(8)
Main:
SERIN 14, 6, [noparse][[/noparse]STR bytearray\8]
DEBUG ? bytearray(0)
DEBUG ? bytearray(1)
DEBUG ? bytearray(2)
DEBUG ? bytearray(3)
DEBUG ? bytearray(4)
DEBUG ? bytearray(5)
DEBUG ? bytearray(6)
DEBUG ? bytearray(7),CR
goto Main
end
Any help would be appreciated.
Thank you,
Steve
On
Off
RGB input
Video input
The baud is 38400.
My input string is:
Main:
goto Main
end
Thank you,
Steve
Maybe your timeout is too long or too short.
Are the codes repeated as long as the user holds the button ?
Bean.
Don't mistake experience for intelligence. And vis-vera.
The problem is, if you put in a timeout, the person could 'press the button' just before the timeout expires. So the SERIN gets one or two bytes, then times-out.
If you don't put in a timeout, the SERIN can sit there FOREVER waiting for the bytes -- it never leaves the SERIN, so never misses any bytes.
Sounds like it's time for a nice, small serial-recieve coprocessor like the:
http://www.rhombus-tek.com/co-processors.html
Use the "Simple Multi-Tasking" module -- gives you a serial input buffer.· Not bad for $12 plus shipping.
Do the strings end with either a CR or LF? If they do, you can tell the SERIN command to watch for the CR or LF. That way, you set up your SERIN to always want 8 bytes, but if the the CR or LF is seen, it fills the last two bytes with nuls.
I think the process is described in the helpfile related to SERIN.
Cheers
Tom Sisk
http://www.siskconsult.com
There are no CR's or LF's at the end of the string.
Does anyone think the faster Stamp would correct this issue?
Just for FYI I will post the code that I just tried.
bytearray6 VAR Byte(6)
bytearray1 VAR Byte
DEBUG "Started", CR
Main:
SERIN 14, 6, [noparse][[/noparse]STR bytearray6\6]
SERIN 14, 6, 1000, debugit, [noparse][[/noparse]bytearray1]
debugit:
DEBUG ? bytearray6(0)
DEBUG ? bytearray6(1)
DEBUG ? bytearray6(2)
DEBUG ? bytearray6(3)
DEBUG ? bytearray6(4)
DEBUG ? bytearray6(5)
DEBUG ? bytearray1
'DEBUG ? bytearray(7),CR
GOTO Main
Main: ' wait for header
char = RX_BYTE
IF char <> "!" THEN Main
char = RX_BYTE
IF char <> "P" THEN Main
char = RX_BYTE
IF char <> "S" THEN Main
char = RX_BYTE
IF char <> "X" THEN Main
Instead of going back to main you could bail out if you id a 6 byte command and keep going for 8.
mydata VAR Byte
main:
SERIN 16,16468,[noparse][[/noparse]HEX mydata]
SELECT mydata
CASE 2
·· 'CODE FOR THE "ON" COMMAND
CASE 3
·· 'CODE FOR THE "OFF" COMMAND
CASE 9
·· 'CODE FOR THE "RGB" COMMAND
CASE 14
·· 'CODE FOR THE VIDEO COMMAND
ENDSELECT
GOTO main
I have to say I couldn't configure 38400 baud but·I captured the last byte everytime at 9600 on a BasicStamp OEM2
Jeff T.
It appears that the first 2 byte give you the an indication of the number of bytes to follow and 2 bytes of 00 that·you can ignore.
Read the first 2 byte and with a little trial and error, an if statement and a pause statement you might be able to time the input and restart at·the 5th byte ··After all that's what bit-serialis all about.
POWER ON: 02 00 00 00 00 02
POWER OFF: 02 01 00 00 00 03
Input 1 RGB 1: 02 03 00 00 02 01 01 09
Input 2 RGB 2: 02 03 00 00 02 01 02 0A
Input 3 RGB 3: 02 03 00 00 02 01 03 0B
Input 4 COMPONENT: 02 03 00 00 02 01 12 1A
Input 5 VIDEO 1: 02 03 00 00 02 01 06 0E
Input 6 VIDEO 2: 02 03 00 00 02 01 07 0F
Input 7 S-VIDEO 1: 02 03 00 00 02 01 0B 13
Input 8 S-VIDEO 2: 02 03 00 00 02 01 0C 14
Input 9 RGB DIGITAL: 02 03 00 00 02 01 1A 22
Input 0 SDI: 02 03 00 00 02 01 1B 23
PICTURE MUTE ON: 02 10 00 00 00 12
PICTURE MUTE OFF: 02 11 00 00 00 13
DISPLAY MUTE ON: 02 14 00 00 00 16
DISPLAY MUTE OFF: 02 15 00 00 00 17
LENS SHUTTER ON: 02 16 00 00 00 18
LENS SHUTTER OFF: 02 17 00 00 00 19
Have Fun
TR
What I did was Serin the first two bytes then put the next four bytes into another array. As long as I get the last byte I can determine what button was pushed. The second byte would always tell me what direction to go whether it was an On/Off or input. With a few If/Then's it worked great. The code ran all weekend with no trouble.
You all were a great help, thanks again,
Steve
