Troubleshooting Debug's WATCH
John Kauffman
Sorry about post without subject line. Will and admin pelase save me the embaressment by deleting the subject-less post? Thanks.
Still some questions with WATCH.·Following is the whole program. I’ve stripped out everything unneeded. I thought this replicated the WATCH examples in the sample programs, but something is off.
DEVICE········· SX28, OSC4MHZ, TURBO, STACKX, OPTIONX
FREQ··········· 4_000_000
MyNum···· ··· VAR· Byte
MyChar ······ VAR· Byte
MyString······VAR· Byte(5)
WATCH MyNum,1,UDEC
WATCH MyChar,1,FSTR
WATCH MyString,5,FSTR
PROGRAM Main nostartup
Main:
MyNum = 5
MyChar = "H"
PUT MyString, "Hello"
BREAK
· GOTO Main
I strike Ctrl+D, it assembles and loads.
Result in Watch Window:
MyNum·········· ‘□’
MyChar·········· 1
Mystring·········· ‘ll○□□’
Any guesses?
WATCH MyNum,1,UDEC
WATCH MyChar,1,FSTR
Main:
MyNum = 5
MyChar = "H"
BREAK
· GOTO Main
MyNum·········· ‘□’
MyChar·········· 1
Any guesses?
Are you hitting RUN from the debug window first ? Otherwise you will see whatever happens to be in those memory locations.
The second parameter for UDEC is BITS so you would need "WATCH MyNum,8,UDEC", however SX/B will put in the parameters. So you can just use "WATCH MyNum" and "WATCH MyString".
Bean.
Don't mistake experience for intelligence. And vis-vera.
Post Edited (Bean (Hitt Consulting)) : 10/13/2006 5:13:28 PM GMT
