adxrs150 — Parallax Forums
adxrs150
SpeakerSpeaker Posts: 34
edited 2006-10-13 03:36 in BASIC Stamp
What is a "dither frame?"
    edited 2006-10-12 19:36
    What's the context? Dither often refers to a pseudo-random process where a pixel is smeared over a larger area because the original information is not available in as high a resolution as expected or required. The smearing is done randomly because the eye does the smoothing.
  • SpeakerSpeaker Posts: 34
    edited 2006-10-13 00:57
    The context is apparently a physical construct. The adxrs150 data sheet is describing how this particular gyro is constructed, and refers to a "dither frame." It's over my head anyway, so it doesn't really matter, but I am curious.
    [noparse][[/noparse]quote]The ADXRS150 operates on the principle of a resonator gyro.
    Two polysilicon sensing structures each contain a dither frame,
    which is electrostatically driven to resonance. This produces the
    necessary velocity element to produce a Coriolis force during
    angular rate. From the spec sheet. It's some mechanical device but just what?
    - Stephen
