what are the PIC and SX chip different.
maxbao
would you tell me· what are the PIC and sx chip different.
why we use sx chip? I am a newer.
thanks
thanks
SX are made by Parallax
PICs have many different types with differing hardware, require 4 cycles for 1 instruction. Run about 20MHz (5 MIPS).
SX have two base types (SX28 & SX48), require only 1 cycle for 1 instruction. Run up to 75MHz (75 MIPS).
Bean.
Don't mistake experience for intelligence. And vis-vera.
How about philosophy of design? That's really at the heart of the difference between the SX and PIC.
The PICs were originally designed as non-von Neumann microcontrollers (which means that the instruction memory is separate from the data memory and, in fact, is normally a different width ... 12 or 14 bits vs. 8 bits). As they became successful and technology improved, additional functionality was added as separate blocks like timers, UARTs, later came USB engines, etc., the instruction set was enlarged with some wider instruction paths as well (like the 18Fxxx series).
The SX had a similar non-von Neumann design, but was intended to be very fast with a deterministic design (you could guarantee that a particular program path would take a certain amount of time) and very short and deterministic interrupt latency (an interrrupt with all the processing involved would take a certain and small amount of time to process). Rather than have lots of separate function blocks and gazillions of different models with different combinations of function blocks, there would be only a few models and most of the functions would be accomplished in software in a way that several functions could be easily combined (like UARTs, etc.)
I am a microcontroller's amateur.I used AT89C and PIC.
I find SX chip on web.I very interest in it.But I
don't know sx need what assemble language.
I can make SX-Ky and SX-Bltz myself?
