Giving Commands to the 2x20 Serial LCD from Matrix Orbital
Hey Everyone,
I'm working on a project that's using the 2x20 LCD display from Matrix Orbital, sold by Parallax.· I can write words to it just fine, the problem comes when I try to give it commands, like clear screen.· Acording to the manual these are the commands for clear screen...
Hexadecimal 0xFE 0x58
Decimal 254 88
ASCII 254 “X”
I can't seem to put these into a program without the BS Editor raising an Error.· Does anyone have an idea of how to use them?
Thanks Everyone
NerdMaster
For
Life
Decimal 254 88
ASCII 254 “X”
Thanks Everyone
NerdMaster
For
Life
·· The following should get you going…
·SEROUT LCD_Pin, Baud, [noparse][[/noparse]254, 88, “Hello World!”]
NerdMaster
For
Life
Chris's answer was kindly, short and fixed your problem, but I'm not sure how much you learned from that. PBASIC will accept any of the number/letter representations which you offered. You just need to tell the PBASIC IDE which representation you are using, as it's certainly no mind reader.
ASCII - Numbers and letters are plain, and all are in quotation marks:
· "A", "B", C", "Hello world", etc. per se
· "1" ," 2", "3", "4", "10", "20", "40", "50", "100" etc. per se
HEX (hexidecimal) - Alphanumeric characters must be preceeded by the Hex designator which is the $ prefix, as follows:
· Decimal 1, 2, 3, 4, 5 , 10, 16
· Hex $01, $02, $03, $05, $0A, $20
DECIMAL - Decomal numbers are plain and without any prefix:
1, 2, 3, 4, 5, 10, 20, 50, 100, etc.
BINARY - Numbers consist of NOTHING but 1's and 0's and are predeeded by the binary designator which is a % sign:
%0, %1, %01, %11, %1010 0101, etc
I hope that is helpful.
Bruce Bates
Post Edited (Bruce Bates) : 10/11/2006 9:48:55 PM GMT
After Chris showed me how to use decimal, I was trying to figure out Hex. I ended up using the HEX command; I almost scraped the LCD by accedently sending it a new baud rate. Wow am I glad it had a manual reset.
NerdMaster
For
Life
