Need help finding an ADC to interface with the BS2... — Parallax Forums
SteelSteel Posts: 313
edited 2006-10-11 00:39 in BASIC Stamp
All of the ADC's that are suggestions for the BS2 have input reference voltages of 0V and +5V.
I have an analog signal that swings from -5V to +5V.· I want to be able to read that signal with my BS2, but I can't find anything.· The TLC0831/32 ratings only read from 0-5V.
Has anybody worked with any ADCs that can have a -5V negative input reference and a 10+V differential?
please help
Shaun
  • Martin HebelMartin Hebel Posts: 1,239
    edited 2006-10-11 00:08
    You can use an op-amp in a summing configuration to add +5 to your input, resulting in a 0 to 10V signal, then you can use a gain of 0.5 to bring it back to 0 to 5V or simply use a voltage divider.
    -Martin Hebel
    Martin Hebel
    Personal Links with plenty of BASIC Stamp info
    StampPlot - Graphical Data Acquisition and Control
    AppBee - XBee ZigBee / IEEE 802.15.4 Adapters & Devices
  • knightofoldcodeknightofoldcode Posts: 233
    Steel said...
    I have an analog signal that swings from -5V to +5V. I want to be able to read that signal with my BS2, but I can't find anything. The TLC0831/32 ratings only read from 0-5V.
    please help
    Shaun
    Look into the Max1270. Voltage readings are from -10 to +10. Input power voltage is +5V.
    Knight.
    This message transmitted with 100% recycled electrons.
    Gravity doesn't exist. The Earth sucks.
    Make a man a fire, and he will be warm for the night.
    Light the man on fire, and he will be warm for the rest of his life.
    Take a look at the MAX1270. It can acquire +/-5 volts even when using a single 5 volt supply.
    www.maxim-ic.com/quick_view2.cfm/qv_pk/1911
    Search this forum for discussion on how to use it with the Stamp.
    Tracy Allen
    www.emesystems.com
