It will give you the pin out of the joystick and other data you will need.
Interface to the basic stamp using the information in what is a microcontroller sections on switches if the joystick you are working with has switches.
Design what you think will work. Post your design here before you fire it up for a pre flight circuit check.
Or
Search this site using the SEARCH button, I put in JOYSTICK and came up with dozens of hits
I did that and here is the first link that came up.
http://www.epanorama.net/documents/joystick/pc_circuits.html
Or
One specific to your question is here:
http://forums.parallax.com/forums/default.aspx?f=5&m=125314&g=125354#m125354
Enjoy, let us know how you do.
Think outside the BOX!
