Transmission (String) Information from PINK to BS2
Could someone tell me how to transmit a string from the PINK (Parallax Internet Network Kit) to the BS2? I trying to figure out the code that enables the BS2 to read and retrieve the content of a variable within the PINK. I trying to switch an LED off/on through the PINK. The BS2 reads the variable from the PINK, and determined by the content if it should be off or on.
see the routines for receiving udp message and sending udp message
