BS2 capability
Has anyone maxed out the capabilities of the BS2?
I would like to use the serin/serout to link to a computer and run the rest of the pins with sonar.
Can the BS2 Support that?
I'm not sure how much power a 'ping' sensor takes -- but since the way they work, you 'trigger' one then read a 'PULSIN' response, then go on to the next, only one is 'active' at a time. At a 'max' distance of 65 mSecs each, 16 'ping' sensors with 'nothing to see' (That's the worst case) would take 1 second per complete scan.
It might be more effective to use 2 'ping' sensors, along with a "PIR" sensor to know when to look, along with a couple of PING steerable servo-mounts. Just an idea.
