10 V 1000ma Rechargable Battery
Hi all.
I just want to ask wethere I can use 10V 1000ma rechargable battery
with my Boe Bot. The normal 4 AA battery drain so fast.
In order to make your BOE-BOT run longer, you want to raise the current capacity (the mah rating), not the voltage. To make it easiest on you, I would suggest finding 4- 2500mah·NiMH AA batteries (or so,·each manufacturer has a slightly different mah value, but as long as its >2000 you should see an improvement) and an appropriate charger for them. This should do the trick without you having to modify your BOE-BOT.
Paul Baker
Post Edited (Paul Baker (Parallax)) : 10/8/2006 3:59:26 AM GMT
These battery packs are usually used for R/C vehicles.
Think outside the BOX!
Randy
