mobile robot project
I’m Building an autonomous mobile robot using differential drive and have a few questions. I’m using two continous rotation modified Hitec 422 servo motors, a Basic Stamp II (education board), two Dubro 2.75 in. wheels, and a NARP 4cm omni direction wheel.
1) If I’m using two HS 422 servo motors and a Basic Stamp II do I need an H-bridge. I was planning on connecting my servo motors to an L293 chip then connecting the L293 to a Basic Stamp, but a classmate told me I didn’t need one, I could connect the servos straight to the Basic Stamp. Please Help!
2) If I need to connect my servos to an H-bridge do I actually open my modified servos and connect the two pins of the motor to the H-bridge.
3) I read a regular caster is a very great ideal for the third wheel, does anyone know a good way to mount an omni directional wheel to an aluminum chassis.
ANY HELP WOULD BE APPRECIATED
<!-- / message --><!-- edit note -->
No H-Bridge is necessary. The width of the PULSEOUT controls both the speed and direction of the servo when it's modified for continuous rotation.
Bruce Bates
<!--StartFragment -->
You state that you are using the 'education board', in which case you can plug the servos into the servo headers and, supplying the board with 6 volts (from 4 1.5 volt batteries) you can use Vin (just set the jumper) for the servo supply.
John
Manxstamp,
Isle of Man, British Isles
require no 7805 regulator or 9 volt battery. The sevos will move quicker with 6 volts than 5 volts. Would this work. An d if so is this the best way to power the servos and board.
