Floating Pins and DeCoupling
Chicago Mike
SO I have a really great project I've finished and I think I've run into a minor issue involving floating pins, which I would like to know how to address on the next thing I build. So here's the scoop. I've got a BS2 on·what I call the mainboard. This has the power supply and other gak. 3 of the pins from the BS2 are run through a 220 resistor network to a .100K connector. This connector also has 2 pins for the 5V rail as well. This connector then has a cable that goes about 18" to a daughter board with a motion sensor and other stuff. Well, everything works GREAT if the daughter board is actually plugged in, but if I unplug the .100k cable from the mainboard. I notice that it seems pin 3 (of these pins I'm remoting) floats around. (Debug commands are showing me this). Its low most of the time, but high sometimes, and if I put my flinger across the connector I can ground it out to zero. (Which is my ideal condition when nothing is plugged in.. OF course minus having to use my finger to ground it out). This isn't a big deal. I can work around it as I've made my own circuit board already, but I was wondering what someone would recommend to add to·pins to ground them out when no 'load' is on them. I guess my queston here is that i want it to default to ground, unless I have a device plugged in? Make sense?
Also, on another note can someone explain what decoupling really is on Ground lines? I notice quite a few devices use small caps .01u on unused pins to ground. Why? Why not just ground them?
Thanks again
Thanks again
