IDE printer problem
I don't know if this helps much but, I found that I can't print my master piece from IDE 3.2 also. I still have the older IDE 3.1 on my system and by loading my program using that it prints fine. I'm using some of SX/B's newer features so it doesn't compile but it will print fine. I'm not sure but I think the problem started appearing after I upgraded to SX/B 1.50
Best,
Jim W.
Best,
Jim W.
I ment to post this in 'http://forums.parallax.com/forums/default.aspx?f=7&m=140481' index out of bounds thread. I don't know how to move it.
The new release 3 of the IDE (version 3.2.r3) fixes the printing problem. You can find it on this page:
www.parallax.com/sx/downloads.asp
Sorry about that. Due to a mix up, the new version isn't posted yet. As soon as I know it's up, I'll make a post.
Thanks, PeterM
Post Edited (PJMonty) : 10/9/2006 4:40:17 PM GMT
Okay, now the correct version of the IDE is up. You can get it here:
There might be a little confusion since the the previous IDE on the page was 3.2r3, and the new one is 3.2.3. The "r3" in the previous case had to do with the installer itself. Trust me. If you have a printing problem, get the new IDE that is version 3.2.3.
Thanks, PeterM
Best,
Jim W.
