PIR sensors
exp1
Hello all,
I have lately bought 10 PIR sensors after I have read the specifications and the datasheets.
I foudn them quite good on papers.
Yesterday the packet came to my home.
I have oponed it and I have tried to run the advanced Demo for basic stamp 2.
Unfortunately after waiting 60 seconds the sensor was only activated when I was actually puttting my habd in front of it. I am speaking for a few centimeters. Otherwise no activation would happen, if the distance was more than a few centimeters.
It seems that I must do someting tiotally wrong.
In addition I saw at the datasheet that the position of the jumper does not matter! So despite that the 'H' and the 'L' is being printed on the PIR's borad; that means that normally the jumper would specify if the sensor is active low or active high, the datasheet states that the position does not matter. Then what is the purpose of the jumper ?
Thank you all for any help that you could give me in order to make these sensors work properly.
http://www.parallax.com/detail.asp?product_id=555-28027
But I have trust to the Parallax products and I thing that I am making something wrong, altough I cannot see what it is.
If somebody could help me I would be grateful.
PIR sensors are slow since they work on thermal changes. Not only do they require a "settling" time, but they react over seconds to large changes in the infrared pattern in an area. Try aiming it into an empty room for a minute or two, then having someone walk into the room.
this is what I have actually done, I left it for a minute and then I tried to walk.
I tried to walk not very far from it.
But no reaction except if I was plaing my hand in front just a few centimeters away.
The idea is a simple alarm system.
Tonight I will try to leave it for 2 minutes before I walk in front of it but I think that it will make no difference [noparse]:([/noparse] unfrotunately.
Anything else to test ?
·· Are all 11 sensors exhibiting the same symptoms you are seeing?· Is the room you’re aiming them into extremely warm?
yesterday I have tested all the 11 sensors.
Fortunately I have seen that the problem was located into only 1. The 1 that I am talking about. From the rest I am pretty happy with their functionality.
The problem with ppl like me from countries that we do not have god distributors (Greece for example) is that I have to buy them from other European countries. In other words I bought them around 118 euros / 11 pieces or in other words or 149 USD.
That's around twice as high as in US.
Now I will have to pay other expenses for sending it back...
If parallax had much less tranferring costs it would be much more economic to buy the products directly from there.
If Parallax used simple ground shipping costs could be something like 5 or 10 at most USD for tranferring a small packet around the world. A microcontroller for example.
Just some thoughts that I think many ppl have done these before but for other reasons these will never happen....
When I say original price I mean the price from parallax.
Of course I bought it from UK.
Thanos
Greekbotics: Greek Robotics Forum
(Translate it using Babelfish)
thank u for the information. I will certianly bare this in my mind.
But again I do not think that it would cost me anything less than 12 euros per piece.
This is the price from UK including transfer cost. I think if I make the math is around there.
But in some cases yes this site might be helpful. I will bare this in my mind.
Thank u again.
it seems a proffesional site.
They accept PayPal as well!
Wow that's maybe the first Greek site that accepts PayPal [noparse]:D[/noparse]
I hope the service to be proffesional as well.
For example I had burned a Javelin chip (my fault) but he has changed the microcontroller for nothing (except the transferring costs)
That's why I buy from there.
So there are more things to think except the price.
In Greece (or Hellas if u like) nobody would ever do something like this.
Am I wrong Thanos ?
I think that you can return any defect product in order not be be your mistake... why don't ask them about it to be sure (info@hellasat.gr)
I know from local electronics stores that returning any item is not alowed as any improper handling may cause damage but this does not apply for fully enclosed products with safety seal.
I bought from them, many parallax products, and I must say I'm satisfied with their delivery service.
Thanos.
Simply they cannot most of the times. But in order to be in the safe side they just do not change it (gr).
On the other hand the UK shops in order to be at the safe side they cahnge it. This is the difference. And of course they win the customers as well.
I have tested everything for the sensor that I am talking about. I thing it had a problem and I have returned it.
as I said all the previous (10) passed my tests successfully [noparse]:)[/noparse] except one.
