Sonar speed useage
AIman
How fast can something be moving and sonar still be effective?
I want to add sonar to my RC plane and car. The car goes upto 45 and the plane 60+. How long will sonar work before speed affects it and if there are problems can I get around them? Will the range of the sonar affect things?
For example Ping))) has a 3 meter range and the SRF10 has a 6 meter range. Does range matter when it comes to speed?
given that, if your car goes 45mph, your creating an "ultrasonic head wind" if you will of about 66ft per second... So your introducing about a 6% error.
with your plane going 60mph, (88ft per second) your error increases to about 8%
ft per second = mph * 1.4667
%error = 1 - [noparse][[/noparse] (Speed of sound in feet) / [noparse][[/noparse] (Speed of sound in feet) + (ft per second) ] ]
Note: This does not take into account any vibration capable of introducing error.
Beau Schwabe
IC Layout Engineer
You're considering the speed to be constant I suspect, and I'd doubt that would be the reality in the field.
Bruce Bates
<!--StartFragment -->
With the exception of vibration playing a significant part, I was expressing a worst case scenario with just speed alone.
Let me know if I'm off base with my assumption.
Beau Schwabe
IC Layout Engineer
Post Edited (Beau Schwabe (Parallax)) : 10/5/2006 3:05:17 PM GMT
At (considerably) higher speeds the Doppler effect of course will need to be considered. The effective frequency goes up, but the resonant frequency of the sonic elements remain unchanged. At velocities below 50ish feet per second this distortion probably still lands within the receiver's resonant pass band, but at over 100ish feet per second it will at least reduce the sensitivity.
But then these speeds are not likely to be considered....... I just bring the point up for interest.
Cheers,
Peter (pjv)
Also, what information do you think you'll get from ultrasound? At the speeds you're discussing, you're not going to 'see' things far enough out to avoid them.
Steve
All the aircraft needs to do is pull up, not distinguish objects and the car is difficult to turn at top speed unless you take wide turns (actually its a T-max truck). Both·R/C vehicles are gas powered so moving the extra weight is a simple matter.
The goal is·for the airplane simply avoid the ground and for the truck avoid an object within its saftey zone.
For that matter, if sonar won't work then what would?
One thing (of many) to ponder is that ultrasound won't detect objects at an angle nearly as well as it will flat-on. Expect the ground to vanish from time to time, and for the distance to vary more with angle than it does with height, and write your software to survive these events.
As for the truck avoiding obstacles at speed, well, I'd do that second...
Steve
