Need help in designing a cct. and writing a program for A MAKE BEFORE BREAK usi
I NEED HELP DESIGNING AND ALSO WRITING A PROGRAM FOR A MAKE BEFORE BREAK CIRCUIT USING THE BASIC STAMP. I WILL BE USING THIS CIRCUIT TO CONTROL 2 RELAYS. BELOW IS AN EXAMPLE OF HOW I WANT IT TO WORK.
····································· OUTPUT
··············································· ···· LED1······· LED2
·································· ····················· H············ L
·····FIRST TRIGGER PULSE········· H············ H
········································ ················L············· H·
Lets presume LED1 is on, with an incoming pulse to the BASIC STAMP i would like LED2 to be turned on following 10 seconds after with LED1 turning off
WITH A SECOND INCOMING PULSE I WOULD LIKE THE REVERSE OPERATION
Lets presume LED2 is on, with an incoming pulse to the BASIC STAMP i would like·led1 to be turned on following 10 seconds after with LED2 turning off
·············································· ···· OUTPUT
············································· ······· LED1······· LED2
··························································L············ H
······SECOND TRIGGER PULSE···· H············ H
··························································H··············L·
IF SOMEONE CAN BUILD AND PROGRAM THIS CIRCUIT FOR ME I WILL EVEN PAY YOU FOR IT.·I DONT HAVE A PROGRAMMER .·MY No. IS (954) 588-0131
