Simple Stepper Code Snippet
Hi All;
There has been some significant activity in the forum recently in regard to software for driving stepper motors. To that end, I have·introduced a callable snippet of code that is a very simple pseudo state machine, and is easy to integrate into anyone's code by just calling it.........
The four entries in the table need to be made to match what your motor needs for each of its step positions; my selection here is arbitrary, just for demonstration.
I hope this is of some help.
Cheers,
Peter (pjv)
Your Code
call Forward ;take a step forward
call Reverse ;take a step backwards
;Step Routines ==============================================================
Forward inc Position ;new forward location and desired motor coil state
call Step ;lookup the new motor state
mov port,w ;output the new motor coil state
retp ;return to mainline
Reverse dec Position ;new reverse location and desired motor coil state
Step mov w,Position ;get the new position
and w,#%0000_0011 ;pay attention only to least significant four states
add pc,w ;jump into the table and return with the coil combination
Table00 retw %0000_0001 ;state 00 return with selected motor coil combination... can be any desired combination
Table01 retw %0000_0010 ;state 01 return with selected motor coil combination... can be any desired combination
Table10 retw %0000_0100 ;state 10 return with selected motor coil combination... can be any desired combination
Table11 retw %0000_1000 ;state 11 return with selected motor coil combination... can be any desired combination
Cheers,
Peter (pjv)
