inputs
i am using the bs2 on my sumo bot to do some playing around with the ds1620 (temp chip) and an lcd.· what i want to do,·simply i thought, was to·create an output based on ambient temp versus my set point and view that on my lcd.· like a thermostat in your house kind of.· so in my program i increment a variable, with a half second delay, continuously with a loop until the button is released.· problem is, when i release the button the input seems to run for an undetermined amount of time.· i watch it on the lcd and on the debug screen and it is high even when i release the button.· i am used to plc inputs and maybe there is something i am missing here.· can someone please help???????
thank you·
thank you·
·· If you·could please post your code we may be able to get some insight as to what is happening.· In the interim I have some BS2 Thermostat Code I have previously posted which used the DS1620.· I can repost it if you think it might be of some use.· It controls the Furnace Relay based on the Set Temp VS Current Temp.
Post Edited (Chris Savage (Parallax)) : 10/2/2006 10:57:51 PM GMT
Sounds like your pin is floating, use a pulldown resistor to make sure the logic level is low when the button is not pressed.
10K resistor from the pin to ground should do it..
Think outside the BOX!
·· Since there was a recent thread where I had posted the Digital Thermostat Code I will just link to that thread.· It is close to the end of the thread.· You will see the message with the attachments.· I hope this helps anyone trying to do something similar.· Take care.
http://forums.parallax.com/forums/default.aspx?f=5&m=140311&p=2&ord=d
