What is the quickest way to drive a servo with just a simple battery and no con
Brann Fenix
This might sound like an odd question, but I am trying to figure out what it takes to drive a servo forward at max power without using a micro controller or a computer. Something on the lines of the Scary Terry audio driver located here http://www.scary-terry.com/audioservo/audioservo.htm is what I am trying for. His circuit drives a servo when it detects sound, but what I need is even more basic than that. All I was to do is connect a servo to the correct voltage and have a push button that powers the server to max when pressed and resets the servo once the button is released. I have not worked with servo at all other than from the BOE-BOT book and if anyone could supply me with a simple circuit or give me any hints that could aid me in this task I would be very greatful.
Thanks in advance,
Brann
Thanks in advance,
Brann
Think outside the BOX!
An ordinary, non-micro controlled R/C servo tester _should_ give you what you need. Here is just such a project nicely layed out:
http://www.seattlerobotics.org/encoder/200210/servoex/ServoExcerciser.htm
You may have to adapt that circuitry somewhat, to meet your specific needs, but 95% of it should be contained within.
Bruce Bates
<!--StartFragment -->
·· Although you asked for no controller, I think the most elegant solution with minimal part count would be to use a BS1-IC.· Aside of that a 556 could probably be setup to generate both pulse values at the same time and a switch used with a logic chip to select which pulse train was being sent to the servo.
I forgot to say it was a standard servo... but thats what happens when you post late at night. You guys gave me all the info I need and more!
Thanks again,
Brann
