LOOKUP with ()'s and []'s
Yendor
Hi Bean,
Glad to see I'm winning!· [noparse]:o[/noparse])
I'm just making sure you'll be employed for a while!·
Another compiler question...Believe me, I'm not trying!!!
I just so happen, by mistake, put brackets around the data of the LOOKUP command as I was adapting·some PBASIC code to SX/B, and the compiler liked it.
LOOKUP Index, [noparse][[/noparse]Con1, Con2, Con3, Con4, Con5, Con6, Con7],·myVar· 'Compiles, Doesn't work
LOOKUP Index, (Con1, Con2, Con3, Con4, Con5, Con6, Con7), myVar· 'Compiles, Doesn't work
LOOKUP Index, Con1, Con2, Con3, Con4, Con5, Con6, Con7,·myVar· 'Compiles, works
Should the compiler complain with the constant's aren't defined, or are·the ()'s useful in the LOOKUP?
Thanks again!
Rodney
Thanks again!
Rodney
I will look at it, it should throw a compiler error.
You are indeed the best bug catcher.
Are you interested in being one of the beta testers ?
Bean.
There are only two guaranteed ways to become weathy.
Spend less than you make.
Make more than you spend.
