Fluorescent lights and wall wart voltage spike
As I was ready to go to bed tonight I turned off the fluorescent light above the panel project I was working on, I use a 12V supply and a 6V wall wart to power the panel. Well it turned off when I turned the light off. Hmm I said and did it again, so I hooked up the scope to trigger on a falling edge connected it to the wall wart (6V wart putting out 9V its a cheap one for sure) here is the electrical glitch that happens when I turn off the light, this 24V spike is somehow generated just by turning the light off when both the light and wall wart are connected to the same AC plug outlet.
The fluorescent light is one of those round bulb types with the magnifying glass in it. It has its own on off switch and that is what triggers this electrical glitch.
It made me wonder about problems people have with intermittant problems and microprocessors and AC power conditions. Adding a cap to the output of the wart lowers the glitch but it is still a pretty big glitch at about 1000uS and 24 volts and the glitch has to do with the AC power line feeding the wart so it is just another wierd and strange problem to deal with.
Think outside the BOX!
Paul Baker
