solder pot controler
I am working on a preheater for a solution that use's a DS2760 thermocouple to measure the fluid as it leaves a 22" coil of copper wire. the wire is heated with a
microwave oven transformer , the primary coil is the imput and the high voltage coil was removed and replaced with two turns of large copper wire which feeds the low votage high current to the preheater's 22"·coil, supplying 0-120 amps like a big Weller soldering gun.The output·is controled now by a light dimmer switch.·I would like to be able to control the exact temperature of the fluid useing my BSPpx24 just like your custom solder pot, what method do you use to control the heating of the solder pot, Analog Input Power or potetiometer control. I know from the article that you use a Crydom SCR too feed the heater to regulate the set-point. That is what I would like to do also, but I am useing a Transformer to control the heat of the coil. Would it be best to control the primary coil with pwm or analog imputs. Thanks David
·· The way you control the heating element really depends on how it is connected as well as the method of control and feedback.· In the case of the solder pot it is set up much like a soldering station, which uses differential gap and a simple thermostat setting.
·· The Solder Pot Controller reads the current temperature of the pot and turns on the SSR to energize the pot whenever the current temp is lower than the set temperature.· The differential gap is adjustable, but typically it is a couple of degrees.
·· In this case it doesn’t matter since we’re using an SSR the pot can toggle on/off as fast as it wants and it will always try to hold the temperature.· PID is not used, so the only time it really overshoots is during initial startup and it is only by a few degrees.· The SSR is a Crydom capable of switching 50A.· I hope this helps.
Does any one Know of a similar process ? Thanks for the help David
·· You could use current control, but with an SSR you’re going to get voltage on/off.· Which is fine for both differential gap as well as PID (See Andy Lindsay’s article in the Stamps In Class Forum).· This will also be easier to control from the BASIC Stamp since it’s merely an on or off state and the I/O pin can almost always directly drive the SSR input.· Take care.
Thanks David
P,S is this OK?
' IntegralAlgorithm.bs2
' Demonstrates how integral control influences error correction
' in a feedback loop.
' {$STAMP BS2p}
' {$PBASIC 2.5}
SetPoint CON 0 ' Set point
Ki CON 10 ' Integral constant
Current CON 0 ' Array index for current error
Accumulator CON 1 ' Array index for accumulated error
sensorInput VAR Word ' Input
error VAR Word(2) ' Two element error array
i VAR Word ' Integral term
drive VAR Word ' Output
DO
DEBUG "Enter sensor input value: "
DEBUGIN SDEC sensorInput
' Calculate error.
error(Current) = SetPoint - sensorInput
' Calculate integral term.
error(Accumulator) = error(Accumulator) + error(Current)
i = Ki * error(Accumulator)
' Calculate output.
drive = i + offset MIN 650 MAX 850
' Display values.
DEBUG CR, CR, "ERROR", CR,
SDEC ? SetPoint, SDEC ? sensorInput, SDEC ? error(Current), CR,
"INTEGRAL", CR,
SDEC ? Ki, SDEC ? error(accumulator), SDEC ? i, CR,
"OUTPUT", CR,
SDEC ? i, SDEC ? drive, CR, CR
LOOP
·· Offset is not being declared as a variable or constant, which is why you’re getting that error.
