Using The Button Command Two Different Routine
Hi, EveyOne
I want to use the Button command to keep looking to see if it PIN gose low and run ONE routine then when it see the pin gose HIGH then run the SECOND routine i doing a project where i will running the BS2 on battery some of the time and some of the time
AC power
How would i do this.
Routine 1
With AC power have the output run the relays and leds
Routine 2
With battery No relays output and no leds On
This will be something that i will be doing very soon
Thank for any help that you can give in this matter
Sam
AC power
Routine 1
Routine 2
Sam
The basic idea I used works like this., ( i'll attach a simple run program of this )
There probally is eaiser or cleaner code by others out there, but this is just my 2 cents, maybe to give ya some direction...
hope it helps.
Thanks for your Post that help alot this will do the job Thank You
·Sam
·······························This is·what i will look like for Holloween···················) ·
······························ Or i could look like these Guys·····························
······················································································· Happy Holloween··· That· all folks
