Control HB-25 Motor Controller by PC LPT1
I intend to use pins of PC LPT1 to control HB-25 Motor Controller.
I'll program to output signal on pins of LPT1 to control HB-25.
Can I do that?
Can I do that?
If this is to be done without a Stamp in the mix, then this post should be moved to the Sandbox forum.
Hint:·If you next question is "can someone here show me code to do this?", then you are seriously cheating yourselfr out of the fun of research...or you have waited too long to do your homework [noparse]:)[/noparse]
Post Edited (Tom Walker) : 9/27/2006 12:57:56 PM GMT
