The bug in SX48/52?
I find the strange work of the SX48 and SX52 MCU's.
This is a simple program for demonstration this bug:
The value of R0 in breakpoint must be 200. Ok?
But it is 201! Why?
When I move "Work" in other program memory address (nor offset + 0x800), all work fine.
When disabled RTCC interrupt, this works fine too.
DEVICE PINS52,OSCHS2 IRC_CAL IRC_SLOW FREQ 5000000 ; May be any offset = 0x004 ; May be other (0x004..0x700..) RESET start org 0x0a R0 ds 1 ; R1 ds 1 ; watch R0,8,udec org 0 jmp @serv start page main jmp main org offset+2 serv reti main Mov RTCC,#19 Mov !option,#10001000b ; RTCC start jmp @Work org offset+0x800 Work nop clr R0 Mov R1,#200 :loop nop nop inc R0 djnz R1,:loop nop break jmp $-1 end
But it is 201! Why?
You need to condense the code to the absolute minimum that still causes the problem.
Bean.
There are only two guaranteed ways to become weathy.
Spend less than you make.
Make more than you spend.
Not everything, but only if the main program and interrupt service routine are on defined distance in program memory space (this distance is near 0x800).
The main program (Work) has two counters - R0 and R1. The R1 is cycle counter, the start value is 200 (as example). R0 is independent counter, = 0 before cycle, and increment every loop.
The interrupt service routine (serv) is dummy, and caused by RTCC rollover every 256 MCU clocks.
The value of R1 after cycle must be equal R0 before it, i.e. 200, not so?
But in this program conditions it is 201!
If the Work routine is on other distance relativelly serv routine, all works ok.
One problem is that the SX52 is obsolete and I'm not sure if I have an SX52 protoboard. Does the problem occur on the SX48 ?
Bean.
On SX48 (0547 prod.) this problem occur too.
It seems to be a debugger issue to me.
Bean.
; Demonstrate the inc/dec bug without debugger ; Need one LED connected from RA.0 to GND ; (whis current limiter resistor, of course) ; When right work, must be one short LED flash after reset ; When this bug occur, the LED stay light. ; Use internal clock oscillator at 32 kHz. DEVICE SX48,OSC32KHZ IRC_CAL IRC_SLOW RESET start org 0x0a R0 ds 1 ; checked counter R1 ds 1 ; cycle counter org 0 ; Interrupt service routine (dummy) nop nop reti start page main jmp main main mov W,#0x1f ; DDIR_W mode mov M,W ; Mov !RA,#11111110b ; RA.0 for output Mov RA,#1 ; The LED is light Mov RTCC,#19 Mov !option,#10001000b ; RTCC start jmp @Work org 0x800 ; The critically routine Work nop clr R0 Mov R1,#200 :loop nop nop inc R0 djnz R1,:loop mov W,#200 ; Check R0 value (here must be 200) xor W,R0 ; Is equal? snz ; Skip if not equal clrb RA.0 ; Switch off LED, if equal (bug not detected) ; If not equal, the LED stay light (bug detected) :q nop jmp :q ; The end (empty unlimited loop) endThis is one more version of bug demo program. It counts errors, and shows errcnt on RA.(0..3).
; Demonstrate the inc/dec bug without debugger (next version) ; Need 4 LED connected from RA.(0..3) to GND ; (whis current limiter resistor, of course) ; When right work, LEDs don't light ; When this bug occur, the LEDs shows 4 bits of error counter ; Use internal clock oscillator at 32 kHz. DEVICE SX48,OSC32KHZ ;DEVICE SX48,OSCHS3 ;FREQ 20000000 ; May be any from 32 kHz up to 20 MHz - uncomment if work with debugger IRC_CAL IRC_SLOW RESET start org 0x0a count1 ds 1 ; Two counters count2 ds 1 ; errcnt ds 1 ; error counter org 0 ; Interrupt service routine (very dummy) reti start page main jmp main main mov W,#0x1f ; DDIR_W mode mov M,W ; Mov !RA,#11110000b ; RA.(0..3) for output clr errcnt ; errcnt = 0 Mov RTCC,#0 Mov !option,#10001000b ; RTCC start jmp @Work org 0x800 ; Critically routine Work clr count1 ; count1 = count2 = 0 clr count2 ; :loop inc count1 ; Counters increment inc count2 ; ;if is no bug, count1 and count2 must be equal here nop ; for odd loop clocks (9) mov W,count1 ; Compare counters xor W,count2 ; snz ; jmp :loop ; Infinite loop if equal inc errcnt ; if not - count errors Mov RA,errcnt ; Show errcnt jmp Work ; Repeat end
