Delay, PIN Command, BaudRate Options & SX-Key Listing Feature Request
I have a few questions I'm running into on my project.· I'm using SX/B v. 1.51.02
1.· DELAY command - After I program the SX using the SX/Key, I'm getting slightly more of a delay on the first DELAY statement than on the second.· After one loop occurs all is fine, and after a reset all is fine.· It's seems to be only after programming.· Here's a snippit of the code:
2.· Now it could be part of the problem, as above.· I'm using the new PIN declariation:
Also, I was suprised that the following gives the same assembly code: EQU RA.1·
Is this correct?
I am setting TRIS_A·in question·#1, above.· A funny thing happens though.· I get invalid data unless I set TRIS_A before adding the initial DELAY statement.· Without, it seems to work fine, as I'm not sure I have an initialization issue or not.
3.· What's the difference betwen·the T and the OT baud modes in the baud rate for SERIN/SEROUT?
4.· I like to copy from the listing page (ctrl+L) and put it into another text editor for comparison (UltraEdit).· Would it be possible within the SX-Key IDE in·the next release to:
Rodney
Main: for idx = 1 to 10 SEROUT Out, Baud, Data PAUSE 500 SEROUT Out, Baud, Data PAUSE 500 next END
However, if I add another pause before the loop, it works fine after programming:
The assembly output looks the same...
Main: PAUSE 500 for idx = 1 to 10 SEROUT Out, Baud, Data PAUSE 500 SEROUT Out, Baud, Data PAUSE 500 next END
MyOut PIN RA.1 OUTPUT
However, doesn't this·declariation make it an output, or should I go ahead and still initilize the A pins, as in:
Start: TRIS_A = %11111111
MyOut1 PIN RA.1 OUTPUT
MyOut2·VAR RA.1
MyOut2·VAR RA.1
Is this correct?
I see in the help file, that T (True)·seems to be no-parity, 8-data bits, and 1-stop bit.··Would "T" also include a start bit too?·What does "Open" mean?· No stop bit?
- Allow ctrl-c to work, once code is highlighted in the Listing·- it seems to only work when I do rightclick-copy.
- Allow the screen to stay where it's positioned in the Listing, instead of jumping back to the top?
- If you close the Listing window, only the listing window should close, not the whole SX-Key IDE which occurs now.
Rodney
· 1) I suspect the clock from the SX-Key is not stable right away. As you say, it works fine after reset.
· 2) "MyOut PIN RA.1 OUTPUT" will make RA.1 an output when the code starts. But "TRIS_A = %11111111" will make ALL pin on RA INPUTS not outputs.
· 3) "OT" serial mode is "OPEN-TRUE" in this mode the serial pin is only driven LOW or is an INPUT. You need to put a pull-up resistor on the pin to make it work properly. This mode is meant to be used in a bus configuration where more than 2 devices are communicating on the same wire.
Bean.
There are only two guaranteed ways to become weathy.
Spend less than you make.
Make more than you spend.
Post Edited (Bean (Hitt Consulting)) : 9/27/2006 12:40:49 AM GMT
On #2 again,
D'oh!·I guess it should have been TRIS_A = %00000000 -·that explains the funnyness.
So, the PIN command effectly sets as output, so nothing is needed to be initalized in a START, using SEROUT, correct?
I'm trying to see what PIN does in assembly.· Is there code·placed else where in the compiled·listing when using PIN, because when looking at the listing of the following, it seems·to be the same:
MyOut2·VAR RA.2
MyOut1 EQU RA.1
MyOut2 EQU RA.2
Again, please execuse the newbie questions, but really appreciate the help!
Rodney
I'm not sure what is going on on your computer, but closing the listing window on mine computer simply closes the list window. The rest of the IDE stays open. How are you closing the list window?
When you say the code in the list window "jumps back to the top," what are you doing that causes this?
Thanks, PeterM
The code to setup the pins is generated by the "PROGRAM" directive.
Bean.
You're right, not sure what's going on with my head when it occurred.· Closing the list window seems works fine.· I could have swarn this happened to me.
As far as jumping back to the top here's the exact procedure:
I'm not sure if this is also an issue to other users, and maybe I'm just a little picky (or there's something else wrong with my head, or my eyes!), but with the font used within the IDE, I'm noticing that 0 (zero) and O (oh) are exactly the same!· Notice here that the O is a little fatter using the Forum font.· Of course this has been a tricky programming issue for generations!
Just some thoughts, and I appreciate the response!
Rodney
If you click over to any window other than the SX list or SX editor, and then back to either SX window, the list scrolls to the top. You're right - this can be annoying.
I have also experienced the IDE closing when you close the list window. For me it only happened when both the editor window and the list window were maximized. But there must be something else that triggers this because I couldn't duplicate it tonight.
Ron
On my machine, I can click back and forth to any app and the list window scroll position doesn't budge a bit. It doesn't matter if I select text, have the cursor in the list window, have text selected - the scroll position stays in place no matter how often I click to another app and then back.
I run Win2K. What OS are you using?
Thanks, PeterM
On my machine (winxp with sp2) the list view also scrolls back to top
when changing to another app and back. Not when changing to sxkey IDE and back to
list view.
regards peter
Ron
I'm running WinXP, SP2, as well, so Peter, thanks for looking into this. It seems to be something with XP.
I guess I need tighter code for now! :O)
Rodney
