Help: IR emitter in TLC555 circuit - not working!
Hello All,
I'm trying to learn the IR emitter/receiver concepts.
Having successfully tested RadioShack IR Emitter&Detector (part# 276-142), as well as the RadioShack IR Receiver Module (part# 276-640) with BS2 to detect the beams (using FREQOUT), I wanted to experiment with 555 timer IC. I have a TLC555 timer IC (RadioShack part# 276-1718).
I connected it based on the circuit diagram shown in page 3 of the following document: http://forums.parallax.com/attachment.php?attachmentid=42602.
When the IR LED is not connected, I am able to tune the potentiometer to 39 kHz . However, as soon as I connect the IR LED, the reading drops to 0 kHz.
I noticed that when I connect a regular LED, it flickers, and the debug message still shows 39 kHz. I also verified that when I connect the IR Emitter, the voltage across the legs drops to millivolts.
I am not sure, where I messed up. Any idea what could have gone wrong?
Thanks in advance!
Thanks in advance!
Thanks for your reply.
I'm quite sure I connected it per the schematic. Its like this: When I pull the IR LED out of the breadboard, the debug indicates ~39 kHz. As soon as I push it back in, it shows 00000 kHz. If I replace the IR LED with a regular (green) LED, the debug still stays at ~39 kHz, and the LED flickers. And I connect both the LEDs the same way - cathode to the grnd, and anode to the 220 ohm resistor leg.
Not sure if this might give a clue, but I found that if I reverse the IR LED connections (ie, anode to grnd, and cathode to the 220 ohm resistor), the debug still indicates ~39 kHz!
Is this possible if the IR LED went bad? What may be the reason for the frequency to drop to 0 kHz as soon as the diode is connected
Confused!
Jeff T.
Did you mean something like the attached pic?
I will test this and let you know if it worked.
Without any changes, the voltage drop is across the IR LEDs (or, p7 and Vss) after it is plugged into the circuit is around 200 mV.
However, when the IR LED is not plugged in, the voltage between p7 and Vss is around 1.5 - 2 v. So, i know the 555 is tuned to generate 39 kHz, but as soon as the IR LED is connected, it just dies off!
Thanks!
Post Edited (likerobots) : 9/26/2006 1:24:25 AM GMT
Jeff T.
