Problem with the NOT operator for array elements in SX/B VERSION 1.51.02
The SX/B NOT operator in 1.51.02 has a problem. When both the operand and the result are array elements, the assembly code generated by the compiler inverts the operand twice.
Here's the code I used to confirm this:
ByteArray VAR Byte(2)
Element0 VAR ByteArray(0)
Element1 VAR ByteArray(1)
Element0 = 0
Element1 = 0
Element1 = NOT Element0
This code leaves Element1 with a value of $00, not $FF as expected.
Of course a simple work-around is to add a non-array byte variable, such as Temp:
Temp = Element0
Element1 = NOT Temp
I also noticed that "NOT" and "~" are not shown in bold in the basic editor. I believe that's because they aren't listed in RESERVED.TXT.
Element0 = 0
Element1 = 0
Temp = Element0
Element1 = NOT Temp
Thanks, I will look into that.
[noparse][[/noparse]edit] Ron, I see what's happening. The value is getting NOT'ed twice. This will be corrected in the next revision.
Thanks again for pointing it out. I put "NOT" in reserved.txt also. Thanks for the catch...
Bean
There are only two guaranteed ways to become weathy.
Spend less than you make.
Make more than you spend.
Post Edited (Bean (Hitt Consulting)) : 9/25/2006 11:34:49 AM GMT
