What is minimum input current on interrupt pins?
I have a project.· My SX is expecting a pulse from another chip as an interrupt.· The chip sends the pulse, and I have an LED indicator showing the pulse is sent...
...But the SX chip is not seeing the pulse.
When I hook 5V to the interrupt pin, it acts as it should...but the SX doesn't seem to be seeing the pulse when it is sent from this chip...(about 20mA).
Are there voltage/current limits on interrupt pins?
thanks.
Shaun
Post Edited (Steel) : 9/22/2006 6:05:23 PM GMT
thanks.
Shaun
The input pins are triggered by voltage level, not by current.
Do you have the LED connected directly to the interrupt pin (or through a resistor) ?
If so, the LED is probably loading it down so it doesn't trigger the SX pin.
Interrupts follow the settings for threshold, so if you didn't change the pin it should interrupt when it crosses 1.4volts.
Possibly the pin is being held above that voltage at all times, that would cause it not to interrupt also.
Try putting a meter on the lead instead of the LED. That will load it down less.
Bean.
There are only two guaranteed ways to become weathy.
Spend less than you make.
Make more than you spend.
