SX/B Crossing Page Boundaries
RonW
With earlier versions of SX/B I had a few problems with code crossing page boundaries. For instance, if the assembly code for a PAUSE crossed a page boundary, there was a problem. Since then I routinely added ADDRESS directives so that no code would execute across a page boundary.
I believe at least some of those problems have gone away. Have those issues all been resolved? Is there any reason to worry about crossing page boundaries with SX/B now?
Thanks.
Thanks.
· You don't have to worry about page boundaries at all as long as you declare your subroutines with SUB all is taken care of by the compiler.
The only thing that can cause problems is if you have a large interrupt routine. Since the interrupt code MUST be before the SUB definitions, alot of interrupt code can push them out of the page. Then you will get an assembly error.
The solution is to make your interrupt a single "GOTO HandleInt", then define your SUBs then put the "HandleInt:" label and your interrupt code.
Bean.
There are only two guaranteed ways to become weathy.
Spend less than you make.
Make more than you spend.
Coders' Hangout
A place for programmers to hangout!
http://www.codershangout.com
METROID?
Metroid Classic
