boe-bot running on playstation controler? — Parallax Forums
WestonWeston Posts: 34
edited 2006-09-23 01:08 in Robotics
i heard that some one figured it out
is there any tutorial on doing this?
because i would like to give this a try
    edited 2006-09-22 02:53
    There are several PS controllers talked about in the basic stamp area http://forums.parallax.com/showthread.php?p=599358 is one of them.
    - Stephen
  • bulkheadbulkhead Posts: 405
    edited 2006-09-22 03:11
    Here's my thread on it in the projects section: http://forums.parallax.com/showthread.php?p=573796
    It's pretty easy to do, buy an adapter (or make your own), wire a simple circuit, copy and paste the program, change the code to make your BOE respond when you move hte joystick in a direction or push a button.
  • WestonWeston Posts: 34
    edited 2006-09-22 20:09
    isthere any way i could just hook up the ps2 controler to the boe-bot?
    i have a plug in for the controller?
    Well its nicer to get an adaptor so you can plug the controller in and out easily. You could just splice the wires on the controller's end, but it wont look as clean, you cant detach it, and you cant use the ps2 controller (for a ps2). You can get a premade adaptor from www.lynxmotion.com for about $15 for one, or you can buy a controller extension cable and cut that to make an adaptor.
