SX/B - Defining constants as negative (two's compliment)
Mike Cook
Having a really basic problem here.
I'm defining a constant as a negative (two's compliment) number:
CDT CON -5 ' Central Daylight Time
When I compile the code and do a <CTRL _L> it compiles as:
185 =00000005 CDT EQU 5 ;CDT CON -5 ' Central Daylight Time
Shouldn't it compile as:
185 =00000005 CDT EQU 251 ;CDT CON -5 ' Central Daylight Time
Sure, wait until I post version 1.51.02 and THEN find a bug.
I'm just kidding of course. Thanks for posting it.
I will look into correcting that.
In the meantime you can use:
CDT CON 0-5
CDT CON 256-5
Bean.
There are only two guaranteed ways to become weathy.
Spend less than you make.
Make more than you spend.
Well that just means if people are finding bugs they are using it (SX/B)!
Great compiler once you learn the rules, I'm still LEARNING!
cbmeeks
Coders' Hangout
A place for programmers to hangout!
http://www.codershangout.com
METROID?
Metroid Classic
