How accurate is the gps
Washer Medic
We have a 100 ft by 400 ft landing strip out in the middle of the farm field would the gps be accurate enough to control an autonomous mower week after week without resetting code ect.
There's nothing a good wack with a hammer won't fix
Darn I let the white smoke out again
looks like 16.4 feet so mowing the lawn would be probbly not a good idea.
I would think you could set up 4 becons though and find the becons via the GPS then mow from there.
Not sure about the resetting code question.
I think I may buy one of these to play with.
Other Specifications
• The navigation update rate of the GPS Receiver Module is once per second.
• High sensitivity (-152 dBm for tracking and -139 dBm for acquisition).
• The Module contains a built-in rechargeable battery for memory and real-time clock back-up.
• On average, the Module has a +/-5 meter position accuracy and a +/-0.1 meter per second velocity accuracy.
Think outside the BOX!
http://home.classicnet.net/dgps/
This figure would probably require WAAS support, and would also vary by field conditions.
If anybody wants to see the Sony datasheet, you can find it on this Sony page:
www.sony.co.jp/~semicon/english/list.html
I need more info on the beacon idea but google is not helping me at the moment can
someone steer me in the right direction
Brian
Post Edited (Washer Medic) : 9/21/2006 6:51:14 AM GMT
Pictures this...A robot is directed to coordinates for which a building stands in the way.· Obviously the robot doesn't know which way is quickest (left or right).· But if you specified via waypoint then the robot knows which way to go and just has to handle smaller distractions/obstacles.
