Question on shift register
As I said in another post, I was going to play with shift registers and I setteles on the CD74HC164E
http://www.datasheetcatalog.com/datasheets_pdf/C/D/7/4/CD74HC164E.shtml
The datasheet is not totally clear to me so please correct my assumptions below
Q0 theu Q7 output
CP clock line
MR resets all to low
VCC and GND or course
Here is where I think I understand it
DS1 and DS2
Use either one for data input but set the other one to logic HIGH to enable the shift register
I see using the shiftout command in the basic stamp (I have leds on outputs) that it works but when the data is shifted into the device all of the output lines get a short high pulse of about 60uS. I understand if the number is 128 for example, the first bit shifted out is a 1, so Q0 is set high aparantly for the time it takes the clock to shift the next bit in, a number of 254 would have Q0 high for 60 * 7 uS during the shifting in.
By making the non dataline DS1 or DS2 LOW while the shift in nothing gets shifted in so it must be held high for the shift register to take data.
Is there a way to eliminate this short pulse on outputs that will be 0 during the shift in of data?
Think outside the BOX!
Q0 theu Q7 output
CP clock line
DS1 and DS2
The question is really just is this the normal operation of this specific device or is there something I am missing. I would imagine a typical use of this device would be to send the serial data and when it is complete signal the device that is actually reading the parallel data that the data is ready, or the device receiving would wait for a minimum time on for all bits but that seems like a waist of clock cycles.
I will read about the other device and usage to get a better idea how a receiving device receives the parallel data on the output pins.
Remember i just hook things up and try and follow the datasheet, like I say it works but the 60uS blink is something I did not expect to see.
I thought it would work similar to using 8 stamp pins where you could change all pins to high or low at the same time, I thought you could send the 8 bits and when the 8th bit was in all bits would reflect the new 8 bit number, this would require the device to have an internal buffer and logic to swap the buffer with the output pins on the falling edge of the last clock cycle.
So just learning the in's and out's of devices i have never used as I think of designs in the future I may say hey i could use a shift register here, that of course requires you to know that they exist.
EDIT>>> Ahhh I see i just read the datasheet (front page) of the 595 it has a buffer and can transfer all 8 bits at one time.
Post Edited (metron9) : 9/20/2006 4:37:29 PM GMT
Don't feel bad about this. I had an EE that should have know better try to use the '164!
