Modulus operator or __REMAINDER Aliases in SX/B v1.51.01
Mike Cook
I'm having a little trouble with the Modulus operator or more specifically the __REMAINDER Aliases in SX/B v1.51.01
From the HELP file under Operators section: Modulus it states:
In my code I'm doing the following:
If Year = 00 then I would expect:
tmp1 = 0
tmp2 = 0
But I actually get:
tmp1 = 0
tmp2 = 255
However If I change the code to:
I get what I expect:
tmp1 = 0
tmp2 = 0
Could this be a bug with the __REMAINDER? Or am I not understanding this correctly?
Note: The remainder of a division (modulus) is available immediately after the division or modulus operation. This code: dig10 = value / 10 dig01 = __REMAINDER ... uses half the instruction space of: dig10 = value / 10 dig01 = value // 10 The only requirement for using __REMAINDER (or __WREMAINDER for word values) is that the assignment to another variable must be the first instruction following the division or modulus operation. "
tmp1 = Year / 4 ' Step 1a. - get a quarter of the year tmp2 = __REMAINDER ' Setp 1b. - save the remainder
tmp1 = 0
tmp2 = 0
But I actually get:
tmp1 = 0
tmp2 = 255
tmp1 = Year / 4 ' Step 1a. - get a quarter of the year tmp2 = Year // 4 ' Setp 1b. - save the remainder
tmp1 = 0
tmp2 = 0
Is YEAR a byte or a WORD ?
The problem is most likely that SX/B will optimize the "/ 4" into shifts instead of doing long division.
But is should still set the remainder properly like you want.
Bean.
There are only two guaranteed ways to become weathy.
Spend less than you make.
Make more than you spend.
· It should work. Do you have any other code between these two lines ?
Bean.
Year is a byte but it is defined this way:
Should that make a difference?
It shouldn't matter. Can you post the code, or send it to me in a PM ?
Bean.
Thanks!
· I just put at the start label:
And when I single step through it, it sets tmp1 to zero and tmp2 to zero (using __REMAINDER)·???
Can you try single stepping it and see what you get ?
Bean.
OK, I've got a 'SXKey' but right now I'm using the 'BLITZ', I have not taken the time to fully learn the full capabilities of the 'SXKey'
What I did do is define
Year = 0
in the START: label and then uncomment:
tmp2 = __REMAINDER
and commented out:
tmp2 = Year // 4
in the GET_DAY SUB
This worked. Now to back out the Year = 0. Commented this line out, saved, recompiled and it STILL works, Now I can't duplicate the problem I was having in my first post.
Boy I need a BEER, Oh well problem solved for now.
Thanks for the quick replies, Ken needs to give you a raise or a case for Propeller Chips!
PROGRAM Start
PROGRAM Start NOSTARTUP
feature. (I was using PROGRAM Start NOSTARTUP to save a few bytes of code space, thought I was handling everything properly in my code.)
If I don't set the Year or Leap variable to ZERO AND compile with PROGRAM Start, power cycle the Board for 30 seconds, it works as expected (no errors)
However if I set:
DON'T define Year or Leap, compile, power cycle the board for 30 seconds, then the error shows up.
I might have expected he first run through of the SUB's to produce bogus results, but would have assumed that the next loop through would fix it's self.
Moral of the story: If you don't know assembly (or what your doing) always use: PROGRAM Start
The old un-initialized variable problem. I spend days (literally) fighting the read-modify-write problem on the color video board. So you got off easy.
Bean.
