lcd screen from calculator help
ok you know if you take a calculator apart and the lcd screen
well i was thinking i could make a calculator or make numbers come up on the screen using the basic stamp
the lcd screen has 28 or somthing like that wires on a strip
any one know what i could do with that??
please help!
please help!
An LCD screen's only like $15, and that's with full documentation. Without documentation, it's pretty hard to put stuff together right.
·· That type of display is called a "field-effect" display, and requires a special driver chip.· You're better off buying an inexpensive Serial or Parallel LCD Display.· Take care.
