Question regarding Toddler / BOE Servos
Ok, so I picked up a BOE-Bot last week, and I've been experimenting with it. I know that when I do a PULSOUT 750 command to a "Parallax Standard Servo", the motor stops moving, as it should. Now, looking through the Toddler manual online, I found this little snippet of code:
So, according to this, sending a PULSOUT of 750 to a toddler motor will center it. Does this mean that unlike the motors from the BOE-Bot, the motors in the Toddler have a "Center" position that is set electronically, that can be called up any time with PULSOUT 750? And is this something that is unique to the Toddler servos? The only reason I ask is because I'm curious to do a walker with the motors I have from the BOE-Bot, and wanted to know if there's a centering option for me using the standard servos. Any help would be appreciated, and hopefully translated into "idiotese", since I'm still fairly new to all of this.
Second follow-up question-
I just realized that the servos for the BOE-Bot are the continuous rotation servos, and the ones in the Toddler are the Mini Servos. Now, I have 2 continuous rotation servos from my BOE-Bot, and I also have a Standard Servo from a BOE-Discovery kit. I noticed that the Standard Servo is like the one above, with Pulseout 750 centering it, but that the 3-pin connecting end has a little plastic flange preventing me from plugging it into my BOE. Can I remove this flange, or is it there to prevent me from using the servo with the board and burning something out?
Many thanks!
-Tom
Post Edited (TTKoshi) : 9/19/2006 9:23:16 PM GMT
' -----[noparse][[/noparse] Title ]----------------------------------------------------------- ' Toddler Program 1.1 - Servo Centering.bs2 ' Electrically center Toddler servos during robot construction ' {$STAMP BS2} ' {$PBASIC 2.5} ' -----[noparse][[/noparse] Declarations ]---------------------------------------------------- TiltServo CON 13 ' Tilting servo on P13 StrideServo CON 12 ' Stride servo on P12 ' -----[noparse][[/noparse] Main Routine ]---------------------------------------------------- Center: ' Center servos with 1500 us pulses PULSOUT TiltServo, 750 PULSOUT StrideServo, 750 PAUSE 25 ' Wait 25 ms GOTO Center ' Repeat
Many thanks!
-Tom
I found the easiest way to remove this flange is to sand it off because if you cut it off you'll need to stand it anyways.
