VSS VDD servo problems. Vss Vdd short causes reset?!
Greetings.· I am a newbie, so· forgive me if this is a silly question:
I recently purchased a Parallax mini servo.· All I am trying to do at this point is get my BS2 to make the servo move.· Following instructions on the parallax site, I created a circuit where I connected two (yes, the correct two) of the servo leads to VSS and VDD and the other to p0 on my BS2.· I copied·some code from the parallax site that shows how to send a "PULSOUT 0,temp" to the pin.· However, when I try to compile and run, the stamp editor (v2.2.6) cannot find my stamp.· I can detach VSS, and am able to complie and run, and then re-plug in VSS, but the Servo does not move.· Also, it seems like my program freezes, and restarts when I unplug VSS.·
I put debug statements in my code, and that·seems to be working fine.· I also put an LED off of PIN0 and was able to verify that I am, in fact, getting a slight pulse out of·pin0.· I have·also tried·using other pins too (P4).
I am using a base board that I got out of a Predko book.· I have verified that I have 5v across VSS and VDD.· Other code on the stamp seems to work fine, provided that I don't directly connect·VSS and VDD.
Interestingly, I have also been able to get the stamp editor to find the stamp if I wire the servo like this:· VSS -> LED -> Servo -> VDD, or even without the servo if I do something like this:·VSS -> LED -> VDD, or VSS -> 470Ohm Resistor -> VDD.· I have been kicking around the idea of using an LM358 to try and isolate VSS/VDD from the servo, but honestly, I am not really sure I know what I am doing, and it just doesn't feel like I should need to do that!
I am using a brand new 9 volt battery to power my board.· And, my board uses a simple serial cable connection.
Is my stamp fried?· (Searching on the internet has lead me to start thinking that a voltage regulator on the BS2 might be destroyed.)·
Is my servo fried?
Any help, ideas, or general comments·would be greatly appreciated.
Thanks!
mporter.
Is my servo fried?
Thanks!
mporter.
The "Robotics with the BOE-Bot" book has a diagram which may be·helpful.
I attached a copy of the page for you.
Note that only the black wires of the servos are common.
·· I don't know about this board you're using or where it gets its Vdd from, but if it's coming from the BASIC Stamp 2 Vdd pin you're drawing far too much current from that pin with even one servo connected.· You cannot drive servos from the BS2 Vdd pin.· You must have a dedicated regulator, such as our BOE has, or you should use Vin, although that is not recommended with a 9V battery.· By the way, a 9V battery won't have the current capacity to run a servo very long before it's too low to power even the BASIC Stamp.· Take care.
Miles.
