rechargable batteries?
i apologize if this question has been asked already... i just read in the "robotics with the boebot" manual that rechargable batteries (nimh etc.) can't be used with the boe, because they are 1.2v instead of 1.5v. is there any way around this? plugging the boebot into the wall seriously cramps it's style, yet i don't want to keep blowing through alkaline batteries...ideas?
thanks,
john
"elementary chaos theory tells us that all robots will eventually turn against their masters and run amok in an orgy of blood and the kicking and the biting with the metal teeth and the hurting and shoving." —professor frink
thanks,
john
Dave
Dave Andreae
Tech Support
dandreae@parallax.com
Http://www.parallax.com
john
There is a jumper on the Board of Education in between the two servo sockets that allow you to choose Vin or Vdd.· Therefore, you can use the 9v rechargeables as long as you make sure to put the jumper in the Vdd position.· It is true that the 9v batteries won't last as long as the AA's, but if you have a couple of them it should be okay.
Dave
Dave Andreae
Tech Support
Post Edited (Dave Andreae (Parallax)) : 9/18/2006 10:08:54 PM GMT
·They·make 1/4 size AA cells they are the same size long but not in dieamter They are 110 miamp hr·nicads·batterys
You could put two packs together which would give you 220 miamp hr and would not be much bigger then 4 AA batterys you would have
room·as the·5 1/4 size AA battery
I do not know if this will help you any but if you are using the battery holder that come with the bot then this might work
What you would have to do to use them·is cut the plastic that hold the cell in place and hot glue them in place
·If so let me know and i will let you how to get them i just order 5 of them for a project that i am working on
Sam
I suspect you are speaking about "N" cells like those in this picture:
http://www.robotroom.com/NCell.html
Bruce Bates
<!--StartFragment -->
Sorry·Bruce· these are·Quad A·the·size
The lenght is about·the same size as the reg AA batteries
These are not N cells these are longer
I just found these batteries at this battery store where i live
I had to order them because they only had one left they are making·7.25 volt pack
If you like i·can give you info
If you like just PM me and i will let you know
Sam······· ·
Post Edited (sam_sam_sam) : 9/27/2006 12:49:26 AM GMT
