PINK, reading the contents of the NB0BM register with the BS2
I read several posts about the "UDP" subject but haven't found a solution to the following problem.
I have a database program that sends a UDP message in XBasic to the PINK. It is recieved by the PINK and I can read the message on the PINK's webpage. Now I want to read the UDP message from the NB0BM register with the BS2.
I wrote the next program to try to read the NB0BM register. But the PINK or BS2 freezes when it encounters the show routine.
The problem is the SEROUT 8,T2400,[noparse][[/noparse]"!NB0BM"] line. I tried !NB0RBM, !NB0WBM, !NB0BM. In the case of !NB0RBM the program restarts from scratch every time an UDP message is recieved??
Does someone have a solution to this problem?
Reagards,
Marcel
dim socketaddress as P
Sockets.datagram_send("192.168.2.6", 10000, "UDP_X10")
' {$STAMP BS2}
' {$PBASIC 2.5}
' M.Kollenaar
' September 2006
' Polling the PINK to act on recieved UDP messages.
NBSTATUS VAR Byte 'Status PINK module.
NBVAR VAR Byte(16)
NewUDP VAR NBSTATUS.BIT5 'UDP updatebit.
T2400 CON 396
DEBUG CLS, "Starting with main module.", CR
MAIN:
DEBUG "Main module", CR
PAUSE 2000
SEROUT 8,T2400,[noparse][[/noparse]"!NB0ST"] 'Poll the PINK
SERIN 7,T2400,[noparse][[/noparse]NBSTATUS] 'Read status register
' DEBUG BIN8 nbstatus
IF NewUDP = 1 THEN show 'Check UDP bit5
GOTO MAIN
END
' Show the the UDP message.
show:
DEBUG "Accessing subroutine SHOW", CR
PAUSE 300
SERIN 7,T2400,[noparse][[/noparse]STR NBVAR\16\CLS]
DEBUG STR NBVAR
RETURN
Reagards,
Marcel
So you must not use return at the end of show,
but goto main.
or use
if newudp = 0 then main
gosub show
goto main
The command to read varBM is !NB0RBM
regards peter
Post Edited (Peter Verkaik) : 9/18/2006 4:51:10 PM GMT
Thanks, both·indications·were the solution! Now it works.
Marcel
