Propeller + solenoid
Hi, I have to interface three small solenoids (about 2cm*2cm, or about 3/4'' square) to the Propeller. I've verified they can be triggered with as little as 3V. I'm used to doing this stuff for 5V mcu's, but I'm not sure hotw to proceed here. I tried with a PNP (2n2907A) with no sucess, with ~5V (unregulated) on the emitter the Propeller on the base and the solenoid between the collector and ground. It didn't work, presumably because the 3.3 aren't high enough. So I'm thinking of pullupus and something like that. Before doing some potentlially dangerous experimenting, does anyone have any advice on how to connect these? Thanks in advance.
