Graphics_demo at 4mhz?
I wired up a RCA type jack to my propeller today with the appropreite resistors.
560 ohm to A15
270 ohm to A14
560 ohm to A13
1.1K ohm to A12
I loaded "Graphics_demo into my eeprom and took it upstairs to my TV and plugged it in. Pressed the reset button and sat back to watch the show, but all I had was a blank screen.
Well... I have 3 questions-
#1 - Can this be run with a 4mhz crystal. This is all I have currently. My local electronics store has a very limited selection, nothing in the way of crystals. I had a few 4 mhz Crystals laying around so I used that. I changed the _xinfreq to 4_000_000 and most programs have run fine. But I'm thinking this may be the reason this program isn't running properly.
#2 - Is a mouse required to run this program? I know it takes inputs from a mouse if one is connected. But is it required?
#3 - is the program set to use pins A12-A15?
Thanks in advance for the help,
Brian
560 ohm to A15
270 ohm to A14
560 ohm to A13
1.1K ohm to A12
Brian
2) It will run without a mouse.
3) It is set to use pins 12-15 by default.
