SX/B - GPS Time & Date Display — Parallax Forums
Mike CookMike Cook Posts: 829
edited 2006-09-17 22:15 in General Discussion
I'm working on a project to control my pool pumps like the www.tightwatt.com timers do. These work great and are X10 compatible, however I wanted something I could tinker with! So this winter while these are controlling my pumps I'm working on a new pump controller project.
Part of the new controller will need a clock, I was going to use a DS1307, but did not want to 'Bloat' the controller code with a setup routine for the DS1307 chip. Since power consumption is not an issue at the moment, I decided to use the next best thing. A clock that sets it's self with no user interaction, a GPS receiver.
The attached code is a small program to display time from the www.allsurplus.net/Axiom GPS Receiver Module. Took parts of the program, listed here:
http://www.parallax.com/dl/src/prod/GISGPS.SXB
and modified for use in this program. Thought I would post this for anyone that might be interested.
  • RsadeikaRsadeika Posts: 3,901
    edited 2006-09-17 21:23
    The project sounds pretty cool, is the GPS device going to be located outside or inside the house? If inside, what kind of reception problems will you have. The reason I am asking is I am still looking for a good, low priced GPS unit for my robot project. Some of the GPS units that I have seen, recomend outdoors use only, probably due to reception problems. Out of curiosity is their any SX/B code to use the unit as a GPS navigation device for a robot.
    Ray
    Since the pumps are outside that's where the controller will live, probably in a NEMA·enclosure. As for the GPS antenna that will be mounted on the enclosure,· so it can have a good view of the sky.
    Post Edited (Mike Cook) : 9/18/2006 12:11:27 AM GMT
