Turntable on Paging System
Is it possible to connect a turntable to a paging system? Someone in a dental clinic I know wants to do this.
Well well, I'm seeing things, three of them.
-Stanley Blystone
-Stanley Blystone
- Stephen
You will probably need an some type of pre-amp with RIAA·correction built-in to connect between the turntable and the paging system.· Check e-bay, these are the same products used to connect a turntable to a computer sound card or a stereo that doesn't have a dedicated turntable input.
Hope this helped!
-Stanley Blystone
No idea on this one, just take a good look at the panel, both front and back.· Also, try to get the maker and model number, with a little internet·searching·you can probably find a manual which would tell you if it has external inputs and where they are.
Do they support stereo sound?
No, mono only.
