Problem BS1 REV D
OK Ihave several of these working over the past few years. I am not real smart on them but I can get my simple program in and going USUALLY. This is the second stamp I have had a problem with this week. The stamps trigger a hockey puck type solid state relays I just wire from the stamp board to the relay using the GND pin for all the -·· Program
'this is the program for thejuggling teddy bear
dirs=%11111111
pins=%00000
start:
pins=%10001
pause 100
pins=%01001
pause· 100
pins=%01010
pause· 100
pins=%00110
pause· 100
pins=%00101
pause· 100
pins=%10010
pause· 100
pins=%10101
debug pins
goto· start
Oh yes the relays energize Christmas lights. I loaded the program and ran it on my laptop using dos. The debug window came up and it displayed debug =21 at each command.I am powering the stamp with a 9 volt battery for now. I took the stamp to the work shop and connected it to the relays with a load on them. It was working oK except it appeared that I had a "flicker" in two outputs or like a quick double output. The battery was only putting out 6.2 V I put in a new battry and it was putting out 8V. The stamp worked good shortly and then shut down. The voltage regulator started to get hot. I disconnected the stamp and hooked to the computer and tried to "run" the program ERROR HARDWARE not found· message. I am trying to figure outwhat I have done wrong. Any help? Don't get tooo technical ha ha
dirs=%11111111
pins=%00000
start:
pins=%10001
pause 100
pins=%01001
pause· 100
pins=%01010
pause· 100
pins=%00110
pause· 100
pins=%00101
pause· 100
pins=%10010
pause· 100
pins=%10101
debug pins
goto· start
Check the datasheets for the SSR.
Are the STAMP pins not going HI/LO?
Do the SSRs work if you hard-wire·the input·On/Off?
Anyway, I (too) think you should drive the SSRs with transistors, using a voltage source other than·the STAMP's +5V (VDD).
Post Edited (PJ Allen) : 9/21/2006 1:00:45 AM GMT
