basic stamp or javelin
Hi I'm looking for some advice for device I am building.
I'm building a device that must:
1. controll two stepper motors in a time sensitive manor (driver boards are not serialy controlled just "enable" "step" and "direction")
2. monitor temperature of the device
3. monitor batery voltage
4. trigger a still camera
5. stamp to pc conection via RF
5. and display the status of the device on an lcd display
the device needs to be able to drive the motors while doing 2-5 without interuption of the system
can anyone recomend the best stamp module to acomplish this? do I need the background procesing functions of the javelin or can a basic stamp 2 acomplish the task.
Owen
Owen
If money is not a problem, and you want bragging rights, and you want to learn Java, the Javelin is a brilliant solution. It is $100 per module, however. It DOES have a LOT of memory compared to the BS2, and DOES have those "virtual I/O devices".
The BS2 MIGHT be able to do it, it depends on the timing you need. The stock BS2 cycles at about 300 uSec per instruction, with NO interrupts.
Certainly the SX/Basic could do it. However, the SX/Basic is not as capable yet as the BS2 PBasic. So there'd be some additional development time there.
Having said all that -- most people expect 'stepper motors' to move pretty synchronized, and it's not likely that a stock BS2 could move them close enough together for them to appear 'synchronized'.· Just a thought.
The Propeller has 8 independent processor cores; you can use as many or as few as you need. In addition, it has a ton of capability built in to the hardware, like video and audio.
Here is a post to a recent article if you are interested in looking into it:
[noparse][[/noparse]url]http://forums.parallax.com/forums/default.aspx?f=25&m=139282[noparse][[/noparse]url]
