RFID Reader Module
All,
I am trying to connect the read tag number to a variable that I can use in IF THEN statements.· I am not understanding very well how you can read from a table of known tags and go to different areas of your program.
Any ideas on how to do this?
Tim
Tim
Go into you PBASIC file and look for LOOKUP or LOOKDOWN, much better then a if..then..else statement!
-Learn somthing about everything, and Everthing about somthing-
Thanks for the help.
Tim
You can look at what i done
I am not sure if will help you any or not
This a project where i need a·different routine for different cards this was the soilder station timer controler at this
Post http://forums.parallax.com/showthread.php?p=595469
And at this Post is where i learned how to write the routine
http://forums.parallax.com/showthread.php?p=586138
Tag1··········· DATA··· "04158DD890"·························· ' valid tags
Tag2··········· DATA··· "04158DCE28"
Tag3··········· DATA··· "04158DCA62"
Name0·········· DATA··· "........STOP.........", CR, 0
Name1·········· DATA··· "Tag 1 (15· MIN· CARD)", CR, 0
Name2·········· DATA··· "Tag 2 (30· MIN· CARD)", CR, 0
Name3·········· DATA··· "Tag 3 (1·· HOUR CARD)", CR, 0
Tag_Found:
ON tagNum GOSUB Routine0,· Routine1, Routine2, Routine3
[noparse][[/noparse]Card's Subroutines ]
' To use differnet Card for differnet amount of Time
' Card # 0 is fot Unauthorized CARD
' Card # 1 is fot 15 Minutes and 00 Seconds
' Card # 2 is fot 30 Minutes and 00 Seconds
' Card # 3 is fot 59 Minutes and 59 Seconds
·'15 Minutes CARD Routine
·Routine1:
· mins=$00
· secs=$00
· GOSUB Set_Time
· HIGH· led·································································· ' Turn ON Relay
· DO
··· GOSUB Get_Time
··· IF mins=$15 AND secs=$00 THEN EXIT
·· DEBUG HOME, HEX2 mins, ":", HEX2 secs, CR
·· DEBUG CR, CR, "15 MIN CARD ", CR
· LOOP
· DEBUG CLS, CLS
· LOW· led···································································· ' Turn OFF Relay
· GOTO main
I hope this helps you with what you want to
Sam
Tim
