Use of the BUTTON command
I can't get the BUTTON command working the way I want.
What I have is 2 buttons named UP and Down.
When I press one of them a counter should count up or down.
When I fast press or use auto repeat the counter should also in/decrease.
This works so far.
But when I stop pressing the program must check the value in the counter and process it.
This part does not work.
As soon as I press the button the prog always enters this check.
Main:
BUTTON Down, 0,400, 20, ButVal, 0, NextBut
DisVal = DisVal - 1·· 'Decrease Counter
GOTO Main
NextBut:
BUTTON Up, 0,400, 20, ButVal, 0, No_Press
DisVal = DisVal + 1· 'Increase Counter
GOTO Main
No_Press:···· ' It should come here only when a button is NOT pressed after some time.· But it comes here even after 1 press and the next (fast) press is ignored.
IF RN = DisVal THEN Hoofd
IF DisVal = 1 THEN r1
This works so far.
Main:
GOTO Main
NextBut:
GOTO Main
As far as I'm aware, EACH Button command should have it's OWN workarea ("ButVal"). Try that and see what happens.
Bruce Bates
<!--StartFragment -->
All I want is press a button, maybe once or maybe more than once.
After the button(s) are quiet for some time then I want process the changes.
I· want to use the Button command to keep looking to see if it PIN·gose ·low and run·ONE·routine then when it see the pin gose HIGH then run the SECOND·routine i doing a project where i will running the BS2 on battery some of the time and some of the time AC power
How would i do this
I·am sorry if i have HIJACK this Post i did not mean to this but this person was asking this·and this will be something that i will be doing very
soon
Thank for any help that you can give in this matter
Sam
