Bypass Capacitors
Alright, i know i was very confused on this and im sure alot of Kids first starting are also,but i want you guys to correct me because again i just researched this, Basically depending on the microfarad ammount, they hold a charge, anything above that charge gets grounded, that prevents noise spikes made by a magnetic field like an alternator, cars are very noisy in this way. Normally Its from an Ac/Dc Mixture and this allows the voltage to remain fairly the same, where if its above the 100uf it sends it to ground, if its under it it releases its charge to make up for the current drop. Am i right? haha
-Learn somthing about everything, and Everthing about somthing-
Please check out these references...
http://www.uoguelph.ca/~antoon/gadgets/caps/caps.html
http://www.swarthmore.edu/NatSci/echeeve1/Ref/FilterBkgrnd/Filters.html
http://www.swarthmore.edu/NatSci/echeeve1/Ref/DataSheet/IntroToFilters.pdf#search=%22Capacitor%20filters%20passive%22
Beau Schwabe
IC Layout Engineer
- Rick
